1992 Ford Ranger starter
JOESPENCER23
  • 1992 FORD RANGER
Computer problem
1992 Ford Ranger 6 cyl Two Wheel Drive Manual
replaced the starter and flywheel, had th computer checked and its okay but now it will start right up somedays then others it will take awhile to start. Could this be the timing. Please help! Thanks a ton
Thursday, September 23rd, 2010 AT 7:03 PM
Next time it refuses to start do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Thursday, September 23rd, 2010 AT 7:30 PM
