1992 Ford Ranger stalling engine
ZIPPO2U
Engine Mechanical problem
1992 Ford Ranger 6 cyl Two Wheel Drive Automatic
i have a 1992 ford ranger 4.0 v6 when i come to a stop sign or red light the idle seems ok but when i go to pull off the engine will either bogg down or cut off all together when it cuts off i have to press the gas pedle to the floor to get it to crank and it may cut off several times again each time i press the gas before i can get it moving again what can cause this?
Mar 20, 2010 at 6:22 AM
  • 75,988 POSTS
Check and test the throttle position and mass airflow sensors and the transmission converter clutch solenoid
Mar 20, 2010 at 8:02 AM
