1992 Ford Ranger JUMPS OUT OF 5TH GEAR
119,000 MILES • 6 CYL • 2WD • MANUAL
AGOODMANBSA
I was having problems with my transmission jumping out of 5th Gear, I pulled the transmission and had it rebuilt, while it was out I replaced the Pilot Bearing, Clutch, U-Joints, & Carrier Bearing.
I installed the rebuilt transmission, Initial test drive around the block was perfect. First trip on the High way, it done it again. The Gears all seem tight. What would cause it to jump out of gear only in 5th Gear.
I know the Input Shaft, Gears, Syncros, Slide Rail & Top Plate was all replaced, as I was given the old parts. Could worn Motor mounts be causing this?
Aug 30, 2010 at 2:30 AM
BILLYMAC
  • 2,204 POSTS
i would suspect the shifter
Sep 12, 2010 at 2:42 PM
AGOODMANBSA
Ended up pulling the Tranny again, the New gear for 5th had a some major pitting on a couple of the teeth. replaced them , every thing fine since
Sep 13, 2010 at 1:08 AM
BILLYMAC
  • 2,204 POSTS
cool atleast you found it
Sep 13, 2010 at 9:36 AM
