1992 Ford Ranger Bogs on Acceleration
PITVIPER1996
I have a 1992 Ford ranger 2.9L v-6 4x4 automatic. Ive put a full tune up plugs, wires, cap, rotor button, and fuel filter on this and it still runs like its clogged up or something.
At idle 9 times out of 10 it runs fine but as soon as i give it fuel it idles up but in a bogged down way. If i hold it at any certain rpm in park the bog stops and it runs smooth. But as soon as i let off and hit the gas again it bogs back down. What could be the source of this?!?
It does have a bad exhaust leak but ive never experianced this kinda problem from an exhaust leak. Any help would be much appreciated.
Aug 10, 2007 at 5:03 AM
BOOTDOG
  • 665 POSTS
a clogged cat converter will do this. see if you can feel any exhaust coming out of the tail pipe or if the cat is hot enough to glow red.
Aug 11, 2007 at 1:37 AM
Suggested Repair
Check for a clogged catalytic converter. Feel for exhaust flow at the tailpipe and see whether the converter is overheating or glowing red.
Conversation Summary
The owner of a 1992 Ford Ranger 2.9L says it bogs when throttle is applied despite a recent tune-up and new fuel filter. Idle is usually fine, and holding a steady RPM in park makes it run smoothly, but it bogs again when the throttle is reapplied. An exhaust leak is also present. The expert suggests a clogged catalytic converter and recommends checking tailpipe flow and whether the converter is glowing hot.
