Fuel Filter
93,000 MILES • 4 CYL • 2WD • MANUAL
KZEIMETZ
I am trying to replace the fuel filter. The hose from the gas tank I disconnected with no trouble. The line going to the engine is metal fitting and I can not see how to disconnect it.
I tried to upload a picture but couldn`t get it to work -- hit the uplaod button and nothing happens
Aug 31, 2010 at 3:56 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Is connection round and can you see like a circle spring inside? if yes need fuel line disconnect tool. Parts house will have under $10
Let me know
Thanks for donate
Aug 31, 2010 at 4:15 AM
KZEIMETZ
The fitting that connects to the out side of the filter is solid metal with the gas hose that goes to the engine crimpted onto it-- I wish I could upload the picture
Aug 31, 2010 at 4:30 AM
DOCFIXIT
  • 18,828 POSTS
Look like this
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_592.jpg
Aug 31, 2010 at 6:56 AM
KZEIMETZ
The fitting to the engine didn`t appear to split like the one in your picture but I finaslly found out what the little plastic tool was for. Put it aroung the shaft of the filter and push it into the body on the gas line steel fitting therefore releasing the holding spring inside,
Thanks for your help
Sep 2, 2010 at 1:56 AM
DOCFIXIT
  • 18,828 POSTS
That's what I though it had a garter spring
Sep 2, 2010 at 3:31 AM
DIECASTER
where is the fuel filter located?
May 20, 2019 at 8:06 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Under vehicle, driver side, below seating area, near fuel tank, mounted on frame rail in fuel line
LOLLYGAGGERJOE
i was driven my truck and it started a little miss than it got worse than it got 2 where it wouldnt run it just kep diein now. i think its the fuel filter but if u know what it is id like 2 know and the location of the filter
RENAUDTN
  • 636 POSTS
To find your filter, just start at the gas tank and follow the fuel line toward your engine. I believe your filter is on the frame rail.
If you never replace your fuel filter before, go ahead and do it; it might fix your problem. It's an easy job (and a cheap one), and even if it doesn't fix your problem it needs to be replaced anyway.
To confirm a problem with your fuel system, do a fuel pressure test; if pressure okay, your filter is not the problem (I would still replace it though).
Come back if you still have the same problem after you replace it.
LOLLYGAGGERJOE
yeah its still doing it i changed the fuel filter and i ran a can of seafoam throw it
RENAUDTN
  • 636 POSTS
-Check your fuel pressure; if low suspect your fuel pump, relay, low voltage at the pump, bad fuel pressure regulator, leaky fuel injectors.
-Check compression in each cylinder; if low suspect leaky/blown head gasket, worn valve, cracked cylinder head.
-Check your ignition system (your must have a strong spark for your car to operate smoothly). If you never replace the plugs and wires, and inspected the coils, now is a good time.
If all the above is okay, you could still have problem with a sensor, or a big vacuum leak.
Have your car scanned for codes if you haven't done it already. It should tell you what the problem is.
TYSONBUBBA
Where is the fuel filter located on a 97 ford ranger 3.0 v6
MIKE H R
  • 3,094 POSTS
the fuel filter is under the drivers side near the rear wheel. it is attached to the frame held in place with a bracket, just before the rear wheels
STARZMD
I have been unable to locate the fuel filter to chang it
I was told it was on the drivers side under the seat aera(next to the frame,any help would be appreciated, thanks marvin
May 20, 2019 at 8:07 AM (Merged)
RENAUDTN
  • 636 POSTS
HI,
I have a 1990 ranger. Although it's not the same year as your, a lot of time different year models are built the same.
I changed my fuel filter a couple of months ago.
It only took me 5 minutes. Mine was located on the driver side, on the frame, under the bed.
Crawl under your truck, look for the fuel line that goes from your tank to your engine. This line is attached to the rail that support the bed; you should find the filter on that rail.
If your is located just like mine, it's not exactly under the driver seat (close though), but more under the bed.
Hope this helps!
