1991 Ford Ranger steaming
1991 FORD RANGER
114,000 MILES • 4 CYL • 4WD • MANUAL
GREGANDKRISTLE
  • 7 POSTS
When I first start the truck up it will steam like crazy. Changed the head gasket, at that time there was water in the oil. But after changing the head gasket, and two new oil changes. It still steams out of the tail pipe, expecially when first starting the truck and then shutting it off and restarting five minutes later. Any clue to my problem?
Oct 21, 2008 at 7:15 PM
BLACKOP555
  • CERTIFIED EXPERT
  • 10,386 POSTS
could be a leaky intake manifold gasket or a cracked intake manifold.
any water in the oil this time?
hows the power steering fluid look, transmission fluid level? coolant level?
when was the last time the fuel filter was changed and water remover added to the gas?
Oct 21, 2008 at 7:44 PM
GREGANDKRISTLE
  • 7 POSTS
no water in the oil this time. transmission fluid level good,power steering good, coolant level, thermastat stuck ,and i changed that today. haved had the truck but for a week didnt check fuel filter yet
Oct 22, 2008 at 12:26 PM
BLACKOP555
  • CERTIFIED EXPERT
  • 10,386 POSTS
ok, so the fluids are good so i would be suspecting bad gas, dirty fuel filter. about all it could be.
Oct 22, 2008 at 7:30 PM
GREGANDKRISTLE
  • 7 POSTS
thanks ill try that. If that isnt it ill get back to you again. Thank you for your time and input on the matter. Thanks again,
Oct 22, 2008 at 9:14 PM
BLACKOP555
  • CERTIFIED EXPERT
  • 10,386 POSTS
glad to help, dont hesitate to post back, even if it does solve it post back would love to hear from you.
Oct 22, 2008 at 9:37 PM
