[quote:6132791ac6="adamg4"]Electrical problem
1991 Ford Ranger 6 cyl Two Wheel Drive Automatic 100,00 miles
replaced ignition mod. ,coil ,computor , crank sensor what else can it be ?[/quote:6132791ac6]
Possibly the ECM or ignition fuse? Check the fuse block under the hood.... Or possibly the ignition switch? You can check the switch by probing it with a test light.
Sep 14, 2009 at 1:42 PM
