1991 Ford Ranger oil leak
YOUNGREBEL18
Engine Mechanical problem
1991 Ford Ranger 4 cyl Two Wheel Drive Manual
hello, 91 ford ranger squirts oil out of the dip stick tube, im not sure if its just a leak,but someone said it might need new motor.. i was wondering what all the possible problems could be.,,,,,thanks for the im put
Feb 19, 2009 at 7:57 AM
BILLYMAC
  • 2,204 POSTS
hi well could be pistons and rings leaking causeing blowby. could be valves .most likely pistons and rings. so yes you are prob looking at a major overhaul. good luck billymac
Feb 19, 2009 at 8:02 AM
