1991 Ford Ranger OIL FILTER PROBLEM - HELP PLEASE ! ! !
CANADIANGUY87
1991 Ford Ranger
Hello, I need help with my oil filter.
So far I have drained the oil and have been trying for the past 2-3 hours to remove the oil filter. It was originally installed by Lub3X (a oil changing shop) over 8 months ago.
Now the problem is that the oil filter won't come off! I used screw drivers, hammers, oil filter wrenches, and the thing won't budge. The other thing is I put a few holes in it to drain the oil so I can't just fill it up with oil again and bring it to a shop.
How do I get the oil filter off? There is very little room to work and the thing is VERY stuck -- like someone put super glue on or something!
Please help me I can't go work because my car won't start!
Jul 11, 2010 at 12:04 PM
  • 75,988 POSTS
When it get stubborn like that I chisel it off
Jul 11, 2010 at 1:21 PM
CANADIANGUY87
But what about the seal? Wont it get stuck and be unable to take out? Do you chisel as in chisel out all the tin and then remove seal or how?
Jul 11, 2010 at 3:09 PM
