1991 Ford Ranger no oil pressure
30,000 MILES • 4 CYL • 2WD • MANUAL
RANGERDANGER17
  • 224 POSTS
the other day i lost oil pressure but as i drove faster the engine stop ticking and the guage said i had pressure again so i replaced the oil pump but now i cant get any pressure and its ticking no matter how fast i go wat do i need to replace to fix this is it the rear main oil seal
Feb 27, 2009 at 10:38 AM
  • 75,988 POSTS
Check the engine bearings
Feb 27, 2009 at 12:23 PM
RANGERDANGER17
  • 224 POSTS
i thought when you lost a engine bearing the engine locked up
the gauge says i got no pressure and i can hear the valves clicking
Feb 28, 2009 at 12:01 AM
  • 75,988 POSTS
Depends on the situation. Best way to know what's happening inside use a mechanical gauge and check the oi pressure if normal repace the oil pressure switch abnormal could mean oil pump and engine bearings
Feb 28, 2009 at 6:41 AM
