1991 Ford Ranger my brake line has hole in it
186 MILES • 4 CYL • 2WD • MANUAL
RANGERDANGER17
  • 224 POSTS
it line to rear brakes its a metal line and a sliver is cut out how do i go about to fix this
do i replace it or fix it with some kind JB weld or cover hose
never mind i got it there is a spilce kit you can buy
May 5, 2008 at 11:11 AM
BLACKOP555
  • 10,386 POSTS
I wouldnt recomned splicing it, unless its a minor hole, that the hose might have been pinched or nicked.
but if its rusted chances are the whole line is starting to deteriorate.
May 5, 2008 at 12:32 PM
RANGERDANGER17
  • 224 POSTS
[quote:b2c4e3c756="blackop555"]I wouldnt recomned splicing it, unless its a minor hole, that the hose might have been pinched or nicked.
but if its rusted chances are the whole line is starting to deteriorate.[/quote:b2c4e3c756]
it was rusted out but i think a rock hit it
buti cant the whole brake line out it is stuckin between the frame and the gas tank
May 5, 2008 at 12:35 PM
BLACKOP555
  • 10,386 POSTS
yes they are a pain to get at! if you ever have the tank down for some reason, get hte line fixed!
May 5, 2008 at 1:37 PM
RANGERDANGER17
  • 224 POSTS
[quote:837c481c78="blackop555"]yes they are a pain to get at! if you ever have the tank down for some reason, get hte line fixed![/quote:837c481c78]
oh i will thats just not a everyday thing and then dont u have to replce the fuel pump cause it normally goes bad after that and there expensive like 200
u have any other ideas
May 5, 2008 at 1:51 PM
BLACKOP555
  • 10,386 POSTS
the pump wont go bad if you drop the tank, its just a pain in the rear!
May 6, 2008 at 12:10 AM
RANGERDANGER17
  • 224 POSTS
[quote:605222b3be="blackop555"]the pump wont go bad if you drop the tank, its just a pain in the rear![/quote:605222b3be]
well thanks for the info but i got it fixed and i ran it alot today and everything worked great
May 6, 2008 at 12:23 PM
BLACKOP555
  • 10,386 POSTS
glad to hear it all worked out.
and i hope you dont run into any more problems with it.
May 7, 2008 at 12:32 PM
