how do you remove power steering pump in order to remove iginition controller?
Dec 12, 2009 at 7:35 AM
✓Experienced Mechanic
Disconnect the battery, remove the belt, and unbolt the mounting bolts for the pump. NOTE: If you need to take the pump out of the vehicle, you need to disconnect the PS hoses too.
