1990 Ford Ranger power booster filling with gas
1990 FORD RANGER
133,000 MILES • 6 CYL • 2WD • MANUAL
LOKIOFASGARD
can anyone tell me why my power brake booster is filling with gas?i've changed it twice and both times it had gas in it which i believe is degrading the membrane and ruining it. the truck has a strong oder of gas when i start it and acts flooded once started it runs o.k.it is fuel injected any help would be appreciated.
Jun 6, 2010 at 11:56 PM
  • 31,937 POSTS
Hi there,
The booster works on engine manifold vacuum, if you have a leaky fuel injector, this is how fuel will be getting into the booster, have the injectors checked.
mark (mhpautos)
Jun 6, 2010 at 11:59 PM
Pull the vacuum hose off the fuel pressure regulator you see gas in it the FPR is gone-replace it
Jun 7, 2010 at 12:00 AM
