Im trying to replace the clutch master cylinder
DNLDHENDERSON
im trying to replace the clutch master cylinder. i got it off the pedal and off the fire wall i just cant get the fluid line off the master cylinder there a pin holding it in and i cant figure it out and theres no bleeder on it so i dont know how to do that eather if u would be able to help me out that would be awesome thanks
Apr 14, 2010 at 8:51 AM
OBXAUTOMEDIC
  • 3,711 POSTS
You would make out better if you desconnect the other end from the Slave and move to a bench or flat surface. You will need to punch out the pin. In order to do so you will need a small punch to tap out the pin you can push in on the line itself to make it a little easier. Once you punch it through enough you can use a pair of pliers to pull out.
To bleed the system you will need an extra person. The bleeder is on the Slave next to the line. Brake the bleeder screw loose first and snug down. Then have the other person pump the clutch peddle about 10 times, have them hold the clutch peddle down and open the bleeder. continue this checking fluid regularly till you get good peddle and no air bubbles.
May 4, 2021 at 3:57 AM
