1990 Ford Ranger Horn doesn't work
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
FREEBIRD5500
1. Fuse diagram...which fuse is the horn?
2. If its not the fuse, other suggestions?
Oct 19, 2008 at 12:44 PM
IMPALASS
  • 3,112 POSTS
Hello I have attached the fuse chart for you. Make sure you just don't take the fuse out and look at it. Use an ohm meter or replace it. It can be hard to see unless it is clearly blown. You can also run wires from your battery and touch the horn connections. If it blows, then the horn is good and we would have to go from there. Hope this helps.
https://images.2carpros.com/forum/automotive_pictures/248015_42309615_1.jpg
Oct 19, 2008 at 2:58 PM
