1990 Ford Ranger
1990 FORD RANGER
146,000 MILES • 6 CYL • 2WD • MANUAL
STEVEN BUSKOHL
My truck occassionally won't turn start unless I turn the ignition 3-5 times. I don't hear any clicking noise like a solenoid or any grinding of the starter. Could it be my ignition or what?
Nov 19, 2009 at 3:25 AM
  • 110,244 POSTS
It could be a relay, solenoid, starter... What I need you to do is this. When this happens, have a helper turn the key to the start position. CHeck the smaller wire on the starter to see if you get power when they turn the key. You should be getting 12+ volts. LEt me know what you find.
Dec 2, 2009 at 12:05 AM
