1989 Ford Ranger Timing sensor
MICKEYADAMS
Engine Mechanical problem
1989 Ford Ranger 4 cyl Two Wheel Drive Manual
To replace timing belt Haynes describes using tool to replace sensor but is vague on how. How do I remove and replace timing sensor on this 2.3 engine.
Aug 3, 2010 at 1:41 AM
SATURNTECH9
  • 30,868 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1989_ford_ranger_crank_sensor_replacement_part1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1989_ford_ranger_crank_sensor_replacement_part2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1989_ford_ranger_crank_sensor_replacement_part3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1989_ford_ranger_crank_sensor_replacement_part4_1.jpg
First of all thank you so much for your donation.Here is the removal and installation and it show's the special tool also.
Aug 3, 2010 at 4:45 AM
KHLOW2008
  • 41,812 POSTS
Hi MickeyAdams, Thank you for the donation. Removal and installation of the sensor is as normal, no special tools required. The only special tool required is for aligning the sensor prior to tightening. The red shaded area is how the special tool should be placed before tightening the sensor.
https://images.2carpros.com/forum/automotive_pictures/192750_Positioning_CrankshaftSensor89RangerFig03_1.jpg
Aug 3, 2010 at 4:46 AM
