1989 Ford Ranger Poor Performence
HUNTERBRUCE
  • 1989 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 94,000 MILES
Have done every thing I can think of new plugs, wires, cap & roter icm, iacm, tp, timeing- stalls & has little power
Saturday, May 15th, 2010 AT 8:48 PM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Saturday, May 15th, 2010 AT 9:29 PM
