1989 Ford Ranger no fluid coming out of rear cylinders
1989 FORD RANGER
DDAILEY1970
MEMBER
1 POST
Brakes problem
1989 Ford Ranger 4 cyl Two Wheel Drive Manual
149.000
Jan 24, 2010 at 10:02 AM
BILLYMAC
✓Experienced Mechanic
Hi your proportioning valve is stuck use this bleed procedure..
loosen bleeder lfront tire. stomp to floor. tighten bleeder same on pass front then pass rear and drivers rear. the stomping forces this valve open..
Jan 25, 2010 at 9:20 AM
