1989 Ford Ranger MAP Sensor
1989 FORD RANGER
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
JMATOUSEK
Can a backyard mechanic like myself replace a MAP sensor on an 1989 Ford Ranger with a V-6? The dealer wants almost $300.00 to do the job with almost $220.00 in labor I know everyone has to eat but I think that this is excessive
Thanks Joe
Feb 20, 2009 at 12:19 PM
THETOOLMAN
  • 123 POSTS
Yes you should be able to change this yourself. Look for the vaccum routing diagram under your hood. The actual name is a VECI Vehicle Emissions Control Information Label. This diagram should tell you where the MAP sensor is located. It usually only has two screws a vaccum line and an electrical connector. Real easy to change. Good Luck
Feb 23, 2009 at 11:26 AM
DAVE H
  • 13,384 POSTS
just a little add on to the toolmans post !!
Manifold Absolute Pressure (MAP) Sensor
MAP sensor measures absolute pressure of mixture in intake manifold and sends a proportional signal to the ECA. It is mounted on right inner fender for 5.0L engine and left inner fender for all others. A vacuum hose is connected between the sensor and the intake manifold.
Feb 23, 2009 at 11:53 AM
THETOOLMAN
  • 123 POSTS
Thanks for the extra info Dave.
Mar 3, 2009 at 1:56 PM
