1989 Ford Ranger
CLIFF SABIN
Engine Mechanical problem
1989 Ford Ranger 4 cyl Two Wheel Drive Manual
This truck has not been started in 2 years. what things should be done before I start it
May 19, 2010 at 2:25 AM
  • 31,937 POSTS
Hi there, pull the plugs out and add a little diesel into the bores this swill help un stick any gummy rings, drain oil & change filter, replace fuel filter and if you can drain they fuel tank and add fresh fuel, check the coolant and then turn over with out the plugs to get a bit of oil pressure up, replace plugs and try a start.
mark (mhpautos)
May 19, 2010 at 2:31 AM
