1988 Ford Ranger oil light and oil pump
1988 FORD RANGER
100,000 MILES • 4 CYL • 2WD • MANUAL
MOMSCOWBELL
my oil light stays on but has plenty of oil in it. is that the oil pump oil a malfunction in the light? and where is the oil sensor located??
Jul 9, 2009 at 6:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Your oil pressure sending unit / switch is on the left rear side of the cylinder head.
You need to use a mechanical oil pressure gauge and make sure your gauge is correct. If the manual gauge shows low pressure than your pump is most likely shot.
Jul 9, 2009 at 7:18 AM
