1988 Ford Ranger ignition wire not hot
RATTLESNAKE
Electrical problem
1988 Ford Ranger 6 cyl
The ignition switch wire on my solenoid does not get hot when you turn the key on. I have replaced the ignition switch. where does the power for the ignition switch come from.
Sep 6, 2009 at 1:23 PM
  • 75,988 POSTS
See below
https://images.2carpros.com/forum/automotive_pictures/12900_fusible_link_3.jpg
Sep 6, 2009 at 2:35 PM
  • 75,988 POSTS
Check the black fusible link at the starter relay and fuse no. 1 this the one that powers the ignition switch
If you are talking about the starter relay not getting power from the switch -check the neutral safety switch-power comes from the ignition switch thru the NSS then to the relay.
Sep 6, 2009 at 3:26 PM
BILLY DAVSI
check the wires for any deteriation. if the wires are green or the plastic is melted then the wires need to be replaced. Make sure that the wires are also big enough to carry the load of amps that are traveling to the ignition if you repalced them, and thy are to small then it will not get enough amps to the system for it to work. also check the ignition coil pig tails, make sure that there is a good connection and that it is plugged in properly. also check the fuse for the ignition, sometimes there is a seperate fuse box for the ignition than for the lights.
Sep 10, 2009 at 3:36 AM
