1988 Ford Ranger Hudraulic clutch system
JMMENDEZ
Transmission problem
1988 Ford Ranger 6 cyl Two Wheel Drive 81000 miles
How do I disconnect the hydraulic line and where is the best place when pulling the engine and transmission together
Feb 9, 2009 at 6:17 AM
GERALD L
bleeding the clutch hydraulics can be a major pain so I reccomend disconnecting clutch petal and removing master cylinder and fluid reservoir and pull them with the engine and tranny. But you can disconnect hydraulics by punching out small pin on master cylinder and pulling hose off.
Feb 11, 2009 at 12:58 AM
