1988 Ford Ranger Flooding problem
150,000 MILES • 4 CYL • 2WD • MANUAL
TIM.BOONE.NC
I have a ranger and i live at 3,000 feet elevation. the carbuerator is doing something funny i think. i try and adjust the fuel-air mixture when its warm, but it still floods out pretty regularly. also im burning through gas alot faster than a 4cylinder car should. i can look down into the (single barrel) carb and see the jets are working fine but it just feels like its lost power and the adjusting screw that i think is the right thing to adjust for the mixture, is turned almost all the way out.
Nov 18, 2009 at 4:29 AM
  • 110,248 POSTS
First, I thought in 1988 they were fuel injected. Regardless, if it has a carb, turn both adjustments in the entire way and back them out 1 and 1/2 turns. Start there to see if you it gets better. You may need to do some fine adjustments from that point, but that is the starting point.
Let me know if this helps. Also, if you are still dumping fuel, make sure the float isn't stuck.
Dec 2, 2009 at 12:27 AM
TIM.BOONE.NC
I think I'm gonna end up rebuilding the carb and cleaning the head. Simple and make it run normally. Thanks man.
Dec 7, 2009 at 2:55 AM
