best way to explain problem is: few mo. ago truck would not run well, finally found crack between valves in #2 cyl. removed & had repaired & replaced. While running down road, I wide open throttle then let off, Truck dies. Pull off road, or get towed day or so later truck starts. This has happened before & after the head repair. With a friend found it had no spark. Replaced : COIL, ECM OR ECA, ENGINE COMPUTER, #4 INJECTOR, MAP SENSOR, EEC POWER RELAY, DIST MOD, as well as the internal dist parts, AIR CHARGE TEMP SENS,COOLANT TEMP SENS, note: thought there was a prob w/enercia switch so I wired the 2 leads together. ANY help? I'd hate to get rid of this truck.
Mar 28, 2010 at 4:18 AM
