1988 Ford Ranger Acting wierd need help
SKYROUNDY
  • 1988 FORD RANGER
Engine Performance problem
1988 Ford Ranger Two Wheel Drive Manual 177000 miles
well my truck sounds good when it is at a idle and even if you rev it up, but when you put it in gear and the engine is warm it will drive just fine with a little bit of throttle and when it is to the floor but if I give it half throttle at between 2500 and 4000 RPM's it cuts out and stutters and loses power what could be wrong with it?
Wednesday, February 11th, 2009 AT 10:59 PM
DAVE H
  • 13,384 POSTS
THROTTLE POSITION (TP) SENSOR
The rotary TP sensor is mounted on side of throttle body and connected directly to throttle shaft. The TP sensor senses throttle movement and position, and transmits an electrical signal to ECA. These signals are used to indicate wide open throttle, closed throttle, or normal cruise conditions.
Thursday, February 12th, 2009 AT 5:52 AM
