HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Drivetrain
Transfer Case
SPONSORED LINKS
1988 Ford Ranger
MERCMAN1
MEMBER
1988 FORD RANGER
1988 Ford Ranger 4 cyl Two Wheel Drive Automatic
I was just wondering if the 2.3 with distributor is an interference motor on a 1988 ford ranger
Friday, October 17th, 2008 AT 8:11 PM
RACEFAN966
MECHANIC
No it does not appear to be an interference engine. If you need anything else let me know.
SPONSORED LINKS
Friday, October 17th, 2008 AT 9:08 PM
MERCMAN1
MEMBER
Now, i'm confused as "just answer @ ford" just told me that it was an interference motor. How do I tell?
Friday, October 17th, 2008 AT 9:24 PM
MERCMAN1
MEMBER
Is there a reason I can't get an answer to this question?
Friday, October 17th, 2008 AT 10:49 PM
RACEFAN966
MECHANIC
I have answered your question. The 2.3 ltr pinto, ranger engine is not an interference engine unless it is a turbo or diesel.
Saturday, October 18th, 2008 AT 11:42 AM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1994 Ford Ranger 4 Wheel Drive
Engine Performance Problem 1994 Ford Ranger 6 Cyl Four Wheel Drive Automatic 140.00 Miles My 4 Wheel Drive Does Not Want To Engaged...
Asked by
nittanita
1994
FORD RANGER
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
Can You Combine A P275/70r16,rear, With A 265/70 R 16...
Can You Combine A P275/70r16, Rear, With A 265/70 R 16, Front, On A 4 Wheel Drive Ranger? Will It Screw Up My 4 Wheel Drive?
Asked by
Drd2012
2007
FORD RANGER
4 Wheel Drive
It Doesnt Go Into 4 Wheel Drive Is There A Fuse For It I Dont Have Oweners Manusl
Asked by
osephus
1 ANSWER
1995
FORD RANGER
When I Lock In My Hubs It Wont Lock Front Wheels, Transfer Case Works And Drive Shaft Turns But Front Wheels Wont Lock. Whats Wrong?
Asked by
longdukdon666
1994
FORD RANGER
No 4x4 At Wheels Does Not Have Vaccum On This Model.94...
4x4 All The Way To Wheel Then No 4x4. It Dont Have Vaccum
Asked by
dlmarsh56
1994
FORD RANGER
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Rear Axle Seal Replacement
Wheel Bearing Hub Replacement
Online car repair manuals
