1987 Ford Ranger starting
170,000 MILES • 4 CYL • 2WD • MANUAL
KARENHONEY08
sometimes when i try to start my ranger it tries to start but doesn'T. I CAN TAKE THE AIRINTAKE HOSE OFF AND SPRAY STARDING FLUID IN IT AND IT WILL START. WHAT IS THE PROBLEM? THANK YOU
Nov 28, 2008 at 3:07 PM
RENAUDTN
  • 636 POSTS
Well, from your description of the problem, it seems like your fuel pressure could be low.
Check your fuel pressure:
It should be around 40 psi (KOEO) for fuel injected models and 5 to 7 psi for carbureted models.
Hope this help
Nov 29, 2008 at 1:23 PM
