1987 Ford Ranger squishy brakes
150,000 MILES • 4 CYL • 4WD • MANUAL
TUFFTRUCK1987
my brakes have no pressure when the truck is running, but if i shut it off, the pressure builds back up.is it the booster? if so, can it be fixed without replacement?
Aug 8, 2009 at 4:27 PM
BLACKOP555
  • 10,386 POSTS
that would not be a issue with the booster. if the booster was bad the brakes would be hard not soft.
check for leaks. is the fluid low?
Aug 12, 2009 at 11:45 AM
