1987 Ford Ranger i need help
MCNALLY
Engine Mechanical problem
1987 Ford Ranger 4 cyl Two Wheel Drive Manual
my truck acks like it isn't getting any gas to it at all. When you start it you must quickly pump the gas to keep it going and as soon as you stop it dies. can you help me figer out what it is? thanks cody nally
May 19, 2009 at 8:17 AM
RENAUDTN
  • 636 POSTS
Hello there,
I would check the fuel pressure first: If I remember correctly you should get between 35-45 psi (KOEO).
Also, check your TPS sensor.
May 19, 2009 at 8:51 AM
