1987 Ford Ranger fuel system
1987 FORD RANGER
SUPERMAN962
Engine Mechanical problem
1987 Ford Ranger 4 cyl Two Wheel Drive Manual 200k+ miles
The engine shut off again without notice, after it had been driven for several miles.This has happened about 5 other times over the past couple months. Before, it would restart with no further trouble. I thought it was a problem with the fuel pump(s) and filter. I am unable to relieve the pressure of the fuel system. I applied 25-28 psi of vacuum pump pressure to the regulator, after removing the gas cap, but the pressure will not relieve. I think there is a problem with the regulator. I really don't know. I'm just gonna start pulling the crap off, whatever happens, happens. GET-R-DONE !! YEE-HAW !! HAY YA'LL, WATCH THIS!! :)
Apr 16, 2009 at 6:12 AM
SUPERMAN962
WHEN IN DOUBT, TAKE IT OUT! BE SAFE.
Apr 17, 2009 at 7:26 AM
