1987 Ford Ranger clutch
1987 FORD RANGER
AIRBORNE09D
Transmission problem
1987 Ford Ranger 4 cyl Four Wheel Drive Manual
my truck is having a hard time going into gear and is making noise while going into gear i think its my clutch but am having a hard time diagnoising the problem
Oct 28, 2008 at 11:18 AM
  • 31,937 POSTS
HI there,
check the clutch fluid level and if low top up and bleed then inspect for the leak, if the level is OK, i would first check the transmission oil level and have a mechanic drive the car and asses the clutch for wear.
Mark (mhpautos)
Oct 28, 2008 at 11:22 AM
