1986 Ford Ranger Stalling in hot weather
REINHARD
1986 Ford Ranger 4 cyl Two Wheel Drive Manual
My Ranger runs great when the weather is cooler but once it warms up quite a bit (1/2 hour or so) it begins cutting out and eventually just stalling out. I'm able to restart it after a few minutes but no power. After it cools off for a hour or two it runs just fine again. Replaced the in tank fuel pump, distributer and coil, catalytic converter and oxygen sensor within the past year. The truck sat for almost 5 years prior to my reviving it about a year ago. I had this problem several months ago where it was cutting out but never stalled (not as hot?) and found that when tapping on the module I could either make it run rough or, if it was running rough, make it smooth out. I took off the module and cleaned all the coagulated dielectric grease of, re-installed it, and it ran fine for a few months till it started acting up again.. Now I've replaced the distributor and module and am having the stalling problem again. I almost suspect that there is too much heat being genrerated under the hood which is affecting the module. My coolant is good, doesn't boil over and the gage seems to act normally (if it's to be trusted). Any ideas? The mechanic suggested I take the dist/module back and get another one as he feels it may be defective but I have my doubts.
Jun 20, 2008 at 4:17 PM
AMRAAM35
  • 39 POSTS
what module are you refering to
Jun 25, 2008 at 2:31 PM
REINHARD
I replaced the TFI module which is mounted on the distributor along with the distributor itself. This last weekend I got a module heat sink bracket from an Aerostar at the wrecking yard and mounted my module in that on the wheelwell as that's a much cooler location (one of the websites suggested doing this as a fix to an apparently common problem with the older Rangers overheating the module due to its' location). This relocation did not fix the problem. I did notice that when I really give it the gas, even when cool, that the truck does hesitate and bucks and cuts out. I don't normally floor it so I never noticed this symptom before and it could very well be tied in with the stalling problem. Regular acceleration seems smooth as can be. Thanks.
Jun 26, 2008 at 12:50 PM
BMRFIXIT
  • 19,053 POSTS
Just few suggestion to through into the hat
check fuel pressure use a set of gauges
check relays
check ignition switch
Jun 26, 2008 at 1:35 PM
