1986 Ford Ranger Replacing the distributor and timing
1986 FORD RANGER
LOANIAC
Engine Mechanical problem
1986 Ford Ranger 6 cyl Two Wheel Drive Automatic 45000+ miles
Bought the vehicle with distributor removed because no spark. Tested and replaced control module and now have spark and need to re-install dist. and time. My question is how to time the dist. to the engine.
Steve
Apr 6, 2009 at 10:11 AM
BLACKOP555
  • 10,386 POSTS
put number one cylinder on top dead center... then put in distributor with the rotor pointing at the #1 spark plug.
from there you run vehicle till warm and then set the timing with a timing light.
Apr 7, 2009 at 12:14 PM
