1986 Ford Ranger idle
100,000 MILES • 4 CYL • 2WD • MANUAL
CHRISMCMAN
wont idle, runs rich
Sep 8, 2009 at 1:18 PM
  • 75,988 POSTS
Running rich:
Could be caused by the following a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Sep 8, 2009 at 1:51 PM
