1986 Ford Ranger Help
120,000 MILES • 6 CYL • 4WD • MANUAL
KJ_2009_09
I have done almost everything i can think of. I bought an 2.9 motor for an automatic so i switched the fly wheel with the old motor then i replaced the gaskets on the top half,i brought the distributer to top dead center on the compression stroke and timed the engine with a timing light to the proper specs,i have checked the tps,egr,eps,map,and the idle air control valve they all check out good.but still the truck barely wants to run what do i do next.
Mar 18, 2009 at 11:56 AM
RANGERDANGER17
  • 224 POSTS
if the engine runs better if you give it gas its the ignition system spark plugs or wires
if it gets worse the more gas you give it its a fuel problem could be fuel pump or filter or injectors try some fuel injector cleaner
also check clogged air filter or clogged exuast pipes
does it smoke any blue smoke is oil white smoke antifreeze
did you have your heads pressure tested the head(s) could be cracked
did you do a compression test
if you have any questions im right here
Mar 18, 2009 at 12:42 PM
KJ_2009_09
what all does the ignition system consist of on the 2.9?
Mar 19, 2009 at 10:49 AM
RANGERDANGER17
  • 224 POSTS
distributor, spark plug wires, and spark plugs
anything else on the ignition either works or it doesnt
Mar 19, 2009 at 12:07 PM
