I have done almost everything i can think of. I bought an 2.9 motor for an automatic so i switched the fly wheel with the old motor then i replaced the gaskets on the top half,i brought the distributer to top dead center on the compression stroke and timed the engine with a timing light to the proper specs,i have checked the tps,egr,eps,map,and the idle air control valve they all check out good.but still the truck barely wants to run what do i do next.
Mar 18, 2009 at 6:56 PM
