1986 Ford Ranger Brake Lights
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRIANNEACE89
The brake lights are always on even if the pedal isn't be pressed and when the truck is off. What could the cause of this be and would it effect my hazard lights, which also just stay on (but the turn signals work fine).
Jan 30, 2010 at 2:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
for the hazards, either a faulty hazard flasher relay or faulty hazard light switch. for the brakes, suspect faulty brake light switch located on brake pedal bracket.
Jan 30, 2010 at 2:40 PM
