1985 Ford Ranger starter
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
TED25
i put a new starter in check the battery the fly whell is fine but the starter just spins and i took it out put back in checked all trhe teeth it was fine if i pull on the belts in moves the gear inside the starter and it will act like it will start but it still does not start
Mar 30, 2008 at 12:07 PM
BMRFIXIT
  • 19,053 POSTS
check with the part store if they gave you the correct unit
check the flywheel try to spin the fly wheel and look if the engine spin and check for a play in the fly wheel
Mar 30, 2008 at 12:21 PM
TED25
well iknow its the right starter i shimed it and know its liked a loud grinding almost i guess when you turn it over
Mar 30, 2008 at 12:25 PM
BMRFIXIT
  • 19,053 POSTS
we ran to the same problem and it was the wrong starter
it will bolt on with no problem but will not make a contact with the fly wheel
good luck!!
Mar 30, 2008 at 12:37 PM
