1985 Ford Ranger ignition
144,000 MILES • 4 CYL • 2WD • MANUAL
MOMMY9397
I can not turn the key to the "run" position to remove the Ignition Cylinder. If I can not turn the key to the Run position as recommended how do I remove the Ignition Cylinder.
Apr 29, 2009 at 1:55 PM
DAVE H
  • 13,383 POSTS
you will have to drill out the lock barrel to release the tumbler's and turn to the run position !!
Apr 29, 2009 at 1:59 PM
