1984 Ford Ranger INTAKE
18,500 MILES • 6 CYL • 2WD • MANUAL
BOSSONE
ON MY 84"RANGE I FOUND A LEAK FROM THE HOSE COMIN FROM THE INTAKE,WELL I FIX THAT , BUT WHEN TAKINGTHE THE SENSOR HOUSING OFF ONE OF THE BOLTS BROKE OFF THE HOLE HAS BEEN
TAP ANDTHEADED BUT ONE PROBEM THE TAP BROKE AS WELL HOW DO YOU FIX THAT ?
Dec 21, 2008 at 11:47 PM
BLACKOP555
  • 10,386 POSTS
your going to have to drill the tap out which will be a very fun job. after that you will have to retap it again, but be careful not to break it.
you could choose to drill the hole larger and get a plug welded in, then from there drill that and tap that.
Dec 28, 2008 at 3:36 AM
