1984 Ford Ranger ignition switch
234,000 MILES • 6 CYL • 2WD • MANUAL
TOOL-WORLD
Hello, my name is Joey and I am fixing up my old truck. I have put a new ignition switch and lock cylinder, but it will not shut off with the key. How can I fix this problem.
Thank You,
Joey Rhodes
Apr 8, 2010 at 9:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
remove the main relay, if engine shuts off then it means the primary circuit is staying hot for some reason, if so check the ground wiring on the circuit
Apr 9, 2010 at 5:16 AM
