1977 Ford Ranger Clutch prob.
150 MILES • 6 CYL • 2WD • MANUAL
JOE DOAKS
Leaks fluid. I refiled it a few times & it worked ok.
But this time it wont go into gear
& if I start it "in gear" it moves with the pedal all the way down.
Jun 26, 2008 at 4:50 PM
KHLOW2008
  • 41,812 POSTS
Hi Joe Doaks,
The clutch master cylinder seals are bad so you need to replace them. If the cylinder bore is bad, you need to replace the whole assy.
Check for leakages along all the hoses and slaver cylinder. I would suggest repairing/replacing the slave cylinider too.
Jun 27, 2008 at 12:52 AM
