1975 Ford Ranger no lights, no starting of any kind
FIXMYFORD
Electrical problem
1975 Ford Ranger 4 cyl Two Wheel Drive Manual
I recently changed a starter relay switch on ford ranger and i accidently shorted something out. Now when i try to turn on the headlights they don't come on and when i turn the ignition key there is nothing
Oct 27, 2008 at 3:38 PM
BMRFIXIT
  • 19,053 POSTS
Need to check the fusible links on solenoid
also make sure you have reconnect all of them back on the battery side
all them fusible links should be connected on same stud with the wire coming from the battery
clip in goes on a small S terminal and big wire coming from the starter goes on the other big stud by it self
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 27, 2008 at 11:26 PM
