2000 Ford Ranger Dragging Brakes
OBLISTA
I have a 2000 Ranger XLT with 87000 miles on it. My truck was recently involved in a minor accident. It has since been repaired. It ran fine before this. When I start my truck and place it in drive and take my foot off the brake, it doesnt roll foward slowly like a vehicle normally should. When driving it seems like its taking too much power to go as fast as I am. I have checked my E-brake and its not on/stuck. Also when I drive for 10+ minutes and I get out I smell something like its burning. I have checked all fluids and all are full, although I do not know how to check the oil to see if its good/bad. However after I have been driving my truck for a little bit it wil roll foward after removing my foot from the brake while in drive. It has the same problems in R/1/2/D. It recently sat for 3 months in Alaska, with tempatures as low as -25. I have also burned almost 1/2 a tank of gas on 65 miles. Any ideas, or anything I could check myself?!?
Thanks
Mar 23, 2006 at 2:40 PM
PEPPERMRJ
  • 1,158 POSTS
Sounds like your first suspicion. I'd bet the brakes are dragging. Feel the wheels after a drive. I'll bet at least 1 is hotter than hell.
Good hunting and let us know. :)
Mar 25, 2006 at 1:51 PM
CH4747
i have a 90 ford mustang 5.0 and i cant get spark i changed the icm , cap , and rotor. the coil is new
Mar 26, 2006 at 11:29 AM
LOVESCARS
  • 359 POSTS
Agreed with peppermj check your front calipers for drag they wil rust and not slide freely
Mar 26, 2006 at 12:06 PM
Suggested Repair
Check for dragging brakes. After a drive, compare wheel temperatures and inspect the front calipers for rust or binding so the pads can slide freely.
Conversation Summary
A 2000 Ford Ranger XLT 4x4 with 87,000 miles felt sluggish after a minor accident repair, would not creep in gear until warmed up, smelled hot after driving, and used excessive fuel. The parking brake was not applied and fluid levels were full. Experts suspected dragging brakes and advised checking wheel heat and front calipers that may be rusted and not sliding freely.
