1971 Ford Ranchero reverse lights
300,000 MILES • V8 • 2WD • AUTOMATIC
EIS MAN
  • 10 POSTS
my reverse lights don't work i have checked for voltage at the light sockets and the ground but its all fine is there a switch and if so where is it?
Oct 1, 2010 at 3:10 PM
HMAC300
  • 48,601 POSTS
if you have votlage there when it's in reverse tehn it's aground problem. if you aren't getting voltage then it may be your neutral sasftey switch. i'd really have to look at a schematic to be sure though. the neutral switch may be on the trans. been a long time since i worked on one of these. I do have a schematic for it though. If you can't find your problem get back with me an dsend me your email and i'll email the schematic but it will take a little time to fin d it.
Oct 23, 2010 at 12:20 PM
