1971 Ford Ranchero distributor
1971 FORD RANCHERO
298,000 MILES • V8 • 2WD • AUTOMATIC
EIS MAN
  • 10 POSTS
hi i was wondering if i could get some advice. The last time i went to adjust the distributor position the thing wouldn't move at all no matter what i tried it doesn't have any other engine problems and the motor isn't even rusty. the motor is a 351 cleveland.
Jul 2, 2010 at 4:24 AM
DOCFIXIT
  • 18,828 POSTS
Very common problem on old Fords dist. via electrolsis sort of welds itself. PB Blaster and channel locks on shaft body can work. Have used propane tourch once If you get it loose set on TDC pull out sandpaper and antiseize compound
Jul 2, 2010 at 7:38 AM
