1969 Ford Ranchero will not move
JOHNHUM
Transmission problem
1969 Ford Ranchero V8 Two Wheel Drive Automatic 0
I have 66 ford ranchero with a new motor and old trans it was shifting so smooth you couldn`t feel it I drove it home parked it next day I started it put it in drive and nothing . fluid is bright red not burnt filled to proper level cable is moving lincage it has a new shift moduale what do you think
Aug 29, 2009 at 11:07 AM
  • 75,988 POSTS
Try engaging the shift linkage manually to a forward gear-if nothing happen get the tranny pressure tested.
Aug 29, 2009 at 11:33 AM
