1997 Ford Puma Heated rear screen
1997 FORD PUMA
FRANKLINENATOR
Electrical problem
1997 Ford Puma 4 cyl Front Wheel Drive Manual
Please can you help, the heated rear screen on my puma no longer works, i have checked the fuse and this is okay, there are some breaks in the filement, which is probably the cause of the problem, can you tell me what i can use to fix this.
many thanks
Paul
Dec 6, 2008 at 6:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Since I am in the U.S. , I just want to clarify that by "rear screen" you are talking about the rear defroster on the rear window?
If so, and you say the filaments in the line are broken, most auto part stores carry or can order a repair kit for this problem. I believe the price is rather cheap too, usually around $10 US Dollars.
Dec 6, 2008 at 6:33 PM
